What is the best & most reliable Mass air for my Novi 2000??
jmyer333
12
I am setting up my Novi 2000 with 42lb injectors on my 93. Looking for the most reliable Mass Air setup for a boosted car. I have seen a lot of press about the DBX but was wondering if a PMAS or Pro-M would do the job.
Thanks
PMAS - check JD's Performance
Pro M - check Jegs
Sorry guys, but Pro M is not PMAS. PMAS used to call themselves ProM PMAS but Pro M made them stop.
I think there is a little confusion here Mike.
I'm referring to using a New PMAS meter or an old Pro M meter. (the ones i would use)
Not sure what's up with the "new" pro m, i've heard that the company has no connection to the old pro m, and that they are using the name to try and sell more meters. I DO NOT KNOW THIS FOR A FACT and could be totally wrong.
MAF
XPR, yep I just bought a new Pro M to replace the old C&L when I put on the Paxton. Turns out that some guys bought the old Prom equipment and starting making meters as Pro m - PMAS. Then either Pro M started back up or some new guys got the rights to the name. There was some back and forth bad mouthing between the two outfits on the internet which pretty much confused everybody. Bottom line is that the new Pro M version seems to be better quality, no rivets and smooth pipe, and it appears from looking at the two websites that Pro M is much the more professional outfit. Anyhow my new ProM solved all my drivability issues. Got it from Jegs.
Ok, i talked to my reliable source about the meters.
Here goes.
PMAS bought all the old Pro m equipment.
The Partners at PMAS had a falling out.
The people who left PMAS bought the older flow equipment that was not being used by PMAS or even the old Pro m.
That's where the new pro m came from.
