i knew someone would ask that ...
i drive like the old man i am.
my typhoon intake is a serious restriction.
my research has indicated that 30# injectors are good for up to 500 horses.
i have 3.27 gears. 4000 rpm in 2nd is like 60 mph, in 3rd it is like 100, and in 4th, it is about 140. i don't need to go past 4000 to go as fast as i want.
under heavy throttle, my AOD shifts 1-2 around 3300 with all kinds of whel spin, 2-3 at about 3500 and 3-4 closer to 3000. believe me, by then, i am going plenty fast enough for my purposes.
i have not yet run it past 4000 rpm and doubt i will ever take it past 4500 rpm. that is just the way i am.
lastly, if i hear pinging, i pull out. should that happen and i determine that the injectors are not keeping up, i'll get 42s again. it is a 30 minute swap.
So is swapping injectors really that easy? I've never tried it before.
I'll be having an AFR 185 headed 11:1 c/r 347 built this summer, so I guess 30 pounders are the standard fare for such an engine? I'm about in the same boat as you as far as revving goes, however I'd probably take it closer to 5500-6000 from time to time.![]()
I did 2 injector swaps this past month. My car, super easy, took like 30 to 45 min. Then my buddies car, his car has some crazy strut tower brace, ac lines & heater lines in the way, trick flow intake thats a pain in the a$$ to remove, took like 2 or 3 hours to swap his. So basicly...it all dependsSo is swapping injectors really that easy? I've never tried it before.
dont listen to this guy, he's cluelessI will compare to my industry. I'm doing high voltage design right now. You never install transmission conductor such that the source can supply more power then the conductor can carry. If this happens the conductor burns down, and repairs cost millions. You always rate the conductor to carry more current then the highest output of the source, so that the conductor is NOT the limiting factor. Make sense?
great suggestion, thanks!Next time you do it at lunch, while the car is running, open the trunk and activate the push button inertia switch underneath the driver's side trunk liner. Its a safety device that activates if your car flips over but you can manually trip it. It kills the fuel pump, and stalls your car out. By killing the fuel pump, it also bleeds out the fuel pressure, so you'll be able to complete the swap without dealing with pressure in the rails. Just don't forget to push it again before you start the car, or you're fuel pump will still be de-activated.
If you're pressed for time at work, you could dissassemble the liner at home so you can pop the trunk and go.
Adam
I can see it there in the trunk. There is a red button on the top that is pressed in. I assume I need to get that red button "un-pressed".... how do you activate it?Next time you do it at lunch, while the car is running, open the trunk and activate the push button inertia switch underneath the driver's side trunk liner. Its a safety device that activates if your car flips over but you can manually trip it. It kills the fuel pump, and stalls your car out. By killing the fuel pump, it also bleeds out the fuel pressure, so you'll be able to complete the swap without dealing with pressure in the rails. Just don't forget to push it again before you start the car, or you're fuel pump will still be de-activated.
Adam
So why make your fuel system the limiting factor? It should be the heads or intake.
$0.02.
Adam
Power lineman?
