installing 30# injectors over lunch
i knew someone would ask that ...
i drive like the old man i am.
my typhoon intake is a serious restriction.
my research has indicated that 30# injectors are good for up to 500 horses.
i have 3.27 gears. 4000 rpm in 2nd is like 60 mph, in 3rd it is like 100, and in 4th, it is about 140. i don't need to go past 4000 to go as fast as i want.
under heavy throttle, my AOD shifts 1-2 around 3300 with all kinds of whel spin, 2-3 at about 3500 and 3-4 closer to 3000. believe me, by then, i am going plenty fast enough for my purposes.
i have not yet run it past 4000 rpm and doubt i will ever take it past 4500 rpm. that is just the way i am.
lastly, if i hear pinging, i pull out. should that happen and i determine that the injectors are not keeping up, i'll get 42s again. it is a 30 minute swap.
here are the main reasons why i am changing injectors.
smaller injectors also allows better control over low rpm fuel delivery because the pulse widths are not as short.
then there is the fact that i can sell my 42# injectors for at least as much as (and probably more than) what i paid for the 30#ers.
So is swapping injectors really that easy? I've never tried it before.
I'll be having an AFR 185 headed 11:1 c/r 347 built this summer, so I guess 30 pounders are the standard fare for such an engine? I'm about in the same boat as you as far as revving goes, however I'd probably take it closer to 5500-6000 from time to time. :)
most people would probably say that 42# injectors is better, on the logic that having more injector than you need is better than not having enough. better safe than sorry.
that is reasonable advice and i have no qualms with that logic.
for a hot engine like you are building, i imaging that 30#s would probably be enough. 42#s will definately be enough. after you have it together and can log your duty cycle, you will have a better feel for what size would work for you.
but for my setup and the way i drive, i am confident that 30# injectors is more than enough injector, and it allows me better control over low rpm fuel delivery.
I did 2 injector swaps this past month. My car, super easy, took like 30 to 45 min. Then my buddies car, his car has some crazy strut tower brace, ac lines & heater lines in the way, trick flow intake thats a pain in the a$$ to remove, took like 2 or 3 hours to swap his. So basicly...it all depends
I will compare to my industry. I'm doing high voltage design right now. You never install transmission conductor such that the source can supply more power then the conductor can carry. If this happens the conductor burns down, and repairs cost millions. You always rate the conductor to carry more current then the highest output of the source, so that the conductor is NOT the limiting factor. Make sense?
dont listen to this guy, he's clueless
still not done ....
it was really windy for 4 days straight, then i had to go out of town sunday.
by windy, i mean up to 30 mph gusts that felt like they do bad things to my hood if it was up when one came.
tuesday was windy again, so i decided to go to a local parking garage to do it. i had 1 1/2 hours. all together. with a 15 minute drive each way and needing to get food and wash my hands and stuff, i gave myself under an hour. the intake came off without drama, but the hoses did not want to come off and i didn't want to force them and break them so i left them on. then i got the first rail off and of course fuel sprayed all over. then i started worrying that if something went wrong and i couldn't get it back together without needing a part, i would be stranded in some parking lot.
that was when i panicked and decided to abort again. :bang:
this weekend is finally going to be sunny and nice, so i am going to do it at home in my driveway and make sure i have the hoses i need and take the intake off completely. and i won't be crunched for time and worrying about getting stranded somewhere, so i am 100% sure i will actually get it done this time.
who would have thought i could turn something mundane like this into a drama?
Next time you do it at lunch, while the car is running, open the trunk and activate the push button inertia switch underneath the driver's side trunk liner. Its a safety device that activates if your car flips over but you can manually trip it. It kills the fuel pump, and stalls your car out. By killing the fuel pump, it also bleeds out the fuel pressure, so you'll be able to complete the swap without dealing with pressure in the rails. Just don't forget to push it again before you start the car, or you're fuel pump will still be de-activated.
If you're pressed for time at work, you could dissassemble the liner at home so you can pop the trunk and go.
Adam
Adam
great suggestion, thanks!
Adam
I can see it there in the trunk. There is a red button on the top that is pressed in. I assume I need to get that red button "un-pressed".... how do you activate it?
So how do the 30's feel? If you want to wait and drive it for a bit to make sure the 30's work, by all means go ahead. Im in no rush for your 42's, and I dont want you to think, "I wish I wouldnt have sold them off so quick."
thanks!
they feel great. the tune change was simple and it started right up and runs great with them.
i have until wednesday to figure out if they are too small. i think i'll throw it in 3rd and wind it up to about 5000 or so and see what the duty cycle is on them
So why make your fuel system the limiting factor? It should be the heads or intake.
$0.02.
Adam
Power lineman?
