Progress Thread We're Back And With A New Project. Build Thread!
They are. Its that there is rtv and dirt in the bottoms of the holes where the valve covers bolt to. We spent hours cleaning them out as best we could but still it wasnt enough to bottom the bolts out. The TFS covers we bought are cast aluminum and have a thick lip where the stamped covers that are on it now are very thin. The thick lip plus the studs should resolve the leak.
I have some small flat wire brushes that I put into a drill and run through small threaded holes, cleans them out perfect...
I use thick rubber composite gaskets from ROL or Mr Gasket..I rtv them to the cover, so they stay with them when you need to remove the covers...works great and reusable. Studs should solve the issue if you already have them on the way, as long as the AFM cover has enough clearance for a washer and nut up top. That is the only problem I have run into with various valve covers and studs ;)
Parts arrived today.
UPR 4" Power Pipe
UPR Clutch Firewall Adjuster
UPR Clutch Quadrant
Thanks Rick91GT!
UPR 4" Power Pipe
UPR Clutch Quadrant
Thanks Rick91GT!
Good stuff.....I should be getting a delivery this week too. Aeromotive FPR, Black Trickflow valve covers and a Trickflow valve cover stud kit. Along with that, the Flaming River steering shaft, Energy motor and tranny mounts, and Walbro 255lph fuel pump are still sitting in the boxes waiting to go in.
Thanks Rick. Will send you an email about suspension ideas, maybe you can help.
I've had a blower before and know about the bypass. This is how it came out of the box. May install it tomorrow sometime. It's a million degrees out. Last night in my garage at 7PM when this arrived, 95 degrees, 100 humidity and zero wind. Soaked just taking that picture.
Just waiting for the MAF adaptor so we can finish the induction completely. The Pro-M Pin adaptor will allow us to run the Lightning 90MM MAF and we can ditch this stock 55MM MAF (which I believe is causing problems anyway). Then we have to take the AFM valve covers off again and install the TFS Stud Covers (which I hope will solve the leaking issue). After all this we should be done under the hood and concentrate on the suspension which is totally shot.
Don't forget when you do eventually up the boost you will want to get a better meter. That Lightning 90mm is only good for about 425-450 rwhp. I used to run one but is easily pegged with aluminum heads and 10psi
Well I will be on vacation starting Friday 15th evening going through the following Saturday 23rd to Mooresville, N.C. Taking my boys to see some big race shops, take a race in at Bowman Grey Stadium. Rog will do some wrenching while I'm gone. Hope to come home with it completely done and doing wheelies down the street.
More parts. TFS aluminum black Coated Valve Covers and Aeromotive Fuel Pressure Regulator. Also will have a gauge on the regulator and we will also add Autoeter gauge inside the car.
Rog is going to drill holes in each valve cover for the breathers. Not only is the lip wider but we are using studs and nuts to secure.
We took 2 weeks off. I went on vacation and visited all the NASCAR shops in North Carolina (check out my thread with 30+ pictures). I just got home Friday night. Rog is at Universal Studios.
We got all the parts. Received the MAF adapter yesterday. We now can use the big 90MM MAF as plug and play. I may install the powerpipe and MAF this week after work. Rog has the other parts (valve covers, fuel pressure regulator, etc.).
We will get back on it next weekend.
We were at it last night (yes weekday) until my Craftsmen Air Compressor bit the dust. Had the that thing for 8 years now. May mess with it tonight, hopefully something easy.
Anyway, I started drilling the TFS valve covers for the breathers. Rog installed the Aeromotive Fuel Pressure Regulator. The induction and AFM valve covers are off the car again. We need to round out the hole in the fender for the UPR Power pipe.
Pics to come tonight, stay tuned.
