Thanks Rick. Will send you an email about suspension ideas, maybe you can help.
I've had a blower before and know about the bypass. This is how it came out of the box. May install it tomorrow sometime. It's a million degrees out. Last night in my garage at 7PM when this arrived, 95 degrees, 100 humidity and zero wind. Soaked just taking that picture.
Just waiting for the MAF adaptor so we can finish the induction completely. The Pro-M Pin adaptor will allow us to run the Lightning 90MM MAF and we can ditch this stock 55MM MAF (which I believe is causing problems anyway). Then we have to take the AFM valve covers off again and install the TFS Stud Covers (which I hope will solve the leaking issue). After all this we should be done under the hood and concentrate on the suspension which is totally shot.
