339rwhp After Tune On Meth, Does This Sound Right?
juiced_94gt
1,143
Southern California
Well I took my car to Adam@STmotorsports in san bernardino. Car made 339RWHP with a vortech s-trim 8lbs of boost, power pipe, 90mm LMAF, Snow stage 2 boost cooler with boost juice, 75mm TB, accufab plenum, stock manifolds, x-pipe w/high flow cats, flowmaster cat-back and the car is automatic.
What gets me is he just turned the dials once for the meth, it seems to me according to light coming on and the boost guage the the meth starts spraying at around 5psi, the other thing is that I had set it up with the intake temp sensor AFTER the nozzle, he made me change that to BEFORE the nozzle, is that correct? I thought the temp sensor was supposed to be after the nozzle to read the cooler temps??? Im confused, should it have made more power?
I am by no means a professional tuner, but the numbers sound pretty close to me. I remember being shocked as hell when I first dynoed my 98 GT and it only put 165 to the wheels. There may be 5-10 more ponies in there but I'd say 339 is pretty close. What is the torque at? My buddy used to always say, "Horsepower is for braggin, Torque is for getting S*** done."
I left there without asking about the tq and no dyno sheet, but he is going to email it to me. what is your combo? My numbers are what I expected for the vortech WITHOUT methanol, with meth I expected at least 380RWHP. Do you run meth also?
2 weekends ago, my car laid down 340 rwhp, 346 rwtq with the mods in my sig (PI motor, blower at 8 psi, exhaust, methanol, AND cams). Almost identical to your setup.
I was telling someone else this just a week or so ago: methanol does NOT show power on a dyno (at least in my experiences). IIRC, I picked up something like 10 or 15 rwhp with the methanol. BUT, it runs like a raped ape at the track. My 340 rwhp, almost 3700 pound, stock converter, stock geared car runs low 12s at 115+ all day long (11s at 118+ with good weather). I have recorded (on several occasions now) that I pick up 5-7 mph with methanol vs. without it. And that's on the same tune with no changes at all, literally flipping the switch.
You definitely need the intake sensor AFTER the methanol (and obviously after the supercharger as well). The computer HAS to know the exact temperature of the air coming into the motor so that it can adjust the timing accordingly. Doing it any other way is half-assed and dangerous for the motor; I lost a motor because it was tuned that way. If you have the meth nozzle after the blower, the sensor needs to be far enough away that the methanol has time to absorb the heat first (so that the sensor isn't just reading the temperature of the methanol). If you have the nozzle before the blower, the sensor can be pretty much anywhere downstream of the blower. This is the way that I have my setup, and the way I think it needs to be done (you increase the adiabatic efficiency of the blower by cooling it down with the meth), but I'm not sure if it's ok to spray meth through a MAF sensor....(assuming your setup is blow-through). I might have to do some research on that....
A few questions before I go any further:
1. How much methanol are you spraying (nozzle size)?
2. What are your IATs (assuming you are measuring the downstream temps)?
3. How much timing is your tuner putting in?
4. What's the air/fuel ratio with and without the meth? Is he adjusting the air/fuel for the methanol (i.e. leaning it out when you spray the methanol)?
Ok two questions:
1. Do i have to retune the car if i move the temp sensor after the nozzle?
2. How far should the nozzle be from the temp sensor?
Ok two questions:
1. It would depend on the current location of the nozzle, the future placement of the nozzle, and on how the tune was done. But ultimately, yes, it would probably have to be redone to be done properly.
2. Ideally, I would say at least 12-14 inches, maybe more if it's spraying directly into it. But it would be different depending on your setup.
Is your setup blow-through or draw through? Where is the IAT sensor located? Where is the MAF located?
I did read that you aren't supposed to spray meth through the MAF unless it was a smaller shot pre-compressor. I know a guy that I consider to be the meth guru of the area; I'll send him a message later this evening and see what he says about it.
In no way does that sound correct...my numbers in my sig are WITHOUT meth and on a blower that generates more heat. Do you have a boost a pump? Did he ever tell you what your fuel pump duty cycle was at? Something is wrong.
I wouldn't necessarily say anything is wrong yet. If the methanol isn't plumbed up the way it should be, and the tuner isn't tuning it the way it should be, then it would be about the equivalent of a non-intercooled setup, which is certainly not much more than 340 rwhp on an auto car. I still want to hear the answers to my questions about the timing, AFR, and other meth stuff before I come to any conclusions. It's quite possible that the tuner simply doesn't know how to tune meth setups.
And depending on the situations surrounding each of your dynos, his numbers might not actually be off that much. His auto is around 6% less efficient than your manual, which bumps him up to about 360 rwhp. If he was on a Mustang Dyno (which reads 10ish% lower than an SAE Dynojet, IIRC), then his Dynojet numbers might be up around 400 rwhp. If he then corrected to STD instead of SAE (which is 4% higher), his numbers are then 417 rwhp. See how easily this stuff can change? Not trying to be condescending, but my car makes 60 less rwhp, weighs around 100 pounds more, and has less gear than your car, but I'm trapping 1-2 mph better than you are. :shrug: Not trying to bash anyone here, just trying to make it understood that dyno numbers aren't everything.
Since you went down that route I would say something seems off. I would definitely check the fuel pressure and duty cycle. I know I'm making more boost....but over 100 horsepower with no meth is a big difference...
If tuned properly, I'll bet his Vortech setup on 8 psi with methanol will run as good or better than your setup, regardless of any dyno says. Now, please, don't take that as a shot against you; I just know that properly setup meth setups run MUCH better at the track than a dyno often indicates they should. My car is a pretty good example of that. There's a TON of Thunderbird guys running setups like mine that are WELL into the 11s at 117+ mph on a 3900 pound car. Got a friend with a Whippled Cobra on methanol; can't remember the dyno numbers, but he was trapping 140+ at full weight on the stock IRS and stock motor.
I'm cant disagree with you because I'm unfamiliar with running methanol. The point i was mskingvis there are guys on this forum running the same setup without methanol and producing 400+ horsepower numbers....he didn't indicate what type of dyno his tuner is using....I'm simply saying that to me it seems as though something is off in the tune of the car. My first pass over the weekend only produced 363hp. When all was said and done I got 455hp. My comment wasn't a "my setup is Vetter than yours" simply that going by what I know and have seen something doesn't equate
I have a vortech, with 10 psi, headers, and full exhaust. I have the stage 2 snow kit and i only made 360 hp on the dyno. the methanol tune only showed about 10 hp on the dyno. I was like you, a little disappointed with the dyno numbers. But, at the track mine runs 12.3's @ 113, that is through a stock automatic trans, with a 1/2 tank of gas, a DA of over 3000 ft, and absolutely nothing removed from the car. Prior to getting tuned, my best pass was a 12.83 @ 108. So with a good tune and meth i was able to pick up 1/2 a second and 5 mph in the quarter. Don't be discouraged with the numbers, if you want a real idea of how your car is performing take it to the track.
Read this on Dynos
http://www.hotrod.com/techarticles/general/hrdp_1103_chassis_dyno_testing/viewall.html
A Dyno is more for tuning than anything. A buddy of mine took his Trans Am to one shop in Vegas, the shop that built it and made 530 hp then a few days latter with no changes took the car to another Dyno and made 430 hp. Of course he brags that he made 530 but the 430 is more realistic for his setup. Try not to get caught up in Dyno numbers. There are a lot of thing that influence the data and the car is only half the store.
Although if changes are made to the car going back to the same dyno is a must because the variations can be so big from dyno to dyno. So find one you trust that will be reliable and consistent and stick to it. To really get an idea take the car to the track and see what it runs.
Oh BTW try to get an air to fuel reading from the dyno run or at least fuel pressure to see if the pump is keeping up. What fuel pump? Do you have a boost a pump? Stock pump with 20 amp boost a pump would be a good setup for you. Read this forum on the focus pump before running one of those, this guy has some experience. http://www.tricktuners.com/forums/showthread.php?t=22
Yea, my bad. I definitely wasn't trying to pit someone's setup vs. another. My point was just that it's VERY possible for a 350 rwhp car to outrun (and out-trap) a 450 rwhp depending on their setups and how nice the dyno and their tuner is.
I have a vortech, with 10 psi, headers, and full exhaust. I have the stage 2 snow kit and i only made 360 hp on the dyno. the methanol tune only showed about 10 hp on the dyno. I was like you, a little disappointed with the dyno numbers. But, at the track mine runs 12.3's @ 113, that is through a stock automatic trans, with a 1/2 tank of gas, a DA of over 3000 ft, and absolutely nothing removed from the car. Prior to getting tuned, my best pass was a 12.83 @ 108. So with a good tune and meth i was able to pick up 1/2 a second and 5 mph in the quarter. .
My experience is almost identical to yours. Low dyno numbers, but runs like a champ at the track (and gains a TON with the methanol).
That is a VERY stout time at that DA. My car only runs around 12.6s at 112 at that kind of DA. For reference, I pick up around .2 seconds and 2 mph for every 1000' of DA (hence my 11.9 @ 118 runs at a -400 ft DA). Your car could easily go 11.7s at 120 with a negative DA. And to think....that's with "360" rwhp....:rolleyes:
:hail:
Skimmed over this thread and just wanted to clairify a couple of things.
Meth before or after the sensor. This mostly depends on whether your meth setup has a safety switch (window switch). If it does, and meth activation is being read and taken into account, the the sensor will should (with few exceptions) be place BEFORE the meth nozzle. This is where the reading will be most accurate and slop for improper atomization for the water/meth doesn't have to be accounted for. Meth activated = More timing and leaner fuel curve. Meth not activated mean less timing and richer fuel curve. Regardless... if your tuner is worth his sand, he has a method for tuning and specific reason for doing it that way. You need to ask question of him and have him explain why he does it the way that he does.
Water/Meth doesn't show on a dyno. It most certainly DOES show on a dyno but as suggested by someone else in this thread, before and after would be relative to the baseline of that SAME dyno and should not be compared to a similar combination belonging to mother's cousin's Aunt's next door neighbor's car who lives 1200 miles away and that their dyno done at Bob's garage on a 30* day with zero humidity. Water/meth effectively decreases ambient air (in this case blower discharge air) temps and increases fuel octane. It's worth quite a bit in terms of timing and Air Fuel Ratio. On my setup, I saw an 80 HP difference and even more torque and this was through much of the power band.
My suggestion would be (since you're running meth) is to run more boost. I wouldn't expect that meth on a vortech making only 8 lbs of boost would be a HUGE difference but meth injection become more and more efficient as the air that it's trying to cool becomes hotter. Add a couple more lbs of boost and you will notice that the water/meth cooled air is not significantly higher than what it is right now with only 8 lbs of boost.
Hope that helps.
Good job of explaining the that Noobz347
The meth/water injection its self doesn't necessarily cause large increases in power but does allow for more timing and boost, it also allows for a little leaner air/fuel mixture there for making more power while avoiding detonation. There is an unintended by product that increases power by the fact that the air is now colder and denser. These increases in power are mostly the effects of water acting as a chemical inter cooler. The meth increases cylinder pressure similar to NOS but far milder in combustion. Methanol is a combustible fuel where NOS is not so there are big differences in that comparison. BTW make sure your fuel pump is up to the task of more boost. Someone correct me if any of the above statements are not accurate just my understanding of it. I am also trying to understand it in more detail because I am thinking of adding it as well.
The ideology there is correct, but it's not feasible. You have one problem (and it's a BIG one). How does a stock ECM know if the meth is spraying or not? I know if you're using one of those flow meters, it can set off bells or whistles or lights or whatever, but it still doesn't tell a stock ECM to adjust the timing or fuel. If you add timing and remove fuel for the methanol in the tune, and then, for whatever reason, the methanol doesn't spray, YOU ARE SCREWED. In my case, the check valve stuck closed, and this was the result:
On a stock computer that doesn't accept external inputs (i.e. flow meters, etc.), there is only one way to properly tune methanol (and the IAT sensor HAS to accurately read the actual temps coming into the motor):
1. Turn the meth off for the tune.
2. Tune the car. Set the AFR at a safe level (12.0ish). Set the timing at a safe level as well (13ish is typical for a non-intercooled 8-9 pounds).
3. Now turn the meth back on.
4. Go back into the tune and add timing based on the cooler IATs. Exactly how to do this depends on the setup and how much the IATs vary. On my setup, the meth easily brings the temps to less than 120, while the temps are well north of 200 without. So if the IATs are less than 140ish, then we KNOW that the methanol is spraying, and it throws the timing to it (from 13 degrees max up to 24 degrees max). If the temps are over 140, then we know that the meth isn't spraying, and the computer simply sticks to the original tune.
5. Finally, and this is CRUCIAL. DO. NOT. ADJUST. THE. AIR/FUEL RATIO. The wideband is going to read that it is richer with the methanol, but because the computer doesn't have a way to adjust the fuel to account for the meth, leaning it out can/will cause the motor to go dangerously lean if the methanol doesn't spray.
And while we're talking about AFR, it needs to be made clear that methanol doesn't richen up the mixture as much as the wideband indicates. A wideband doesn't measure the AFR, it measures lamda and then calculates the AFR based on the stoichemetric ratio we have it programmed for (14.7 is most cases). Because methanol's stoichemetric ratio is much less than gasoline's (6.5 vs. 14.7), the lamda value read by the wideband is going to be lower, as is the actual stoichemetric ratio. However, since we aren't reprogramming the wideband for this lesser stoichemetric ratio, it is going to read richer than it actually is.
I haven't done the calculations myself (yet), I've been told by some folks that know that my setup is only enriching up about .3-.4 point, even though the wideband indicates that it's over a point richer. And I am spraying a LOT of water/meth (14 GPH of 70/30 water/meth).
Hope that helps.
It shows on some setups. You gained 80 rwhp; Winters has showed nice gains on his Vette; I know others that have as well. But it simply does not show on some setups. I just went and looked at my dyno graph from when it was tuned; I gained 13 rwhp and 0 rwtq on the methanol. However, on the same tune, same car, same weight, same track, same time, same EVERYTHING except the flip of a switch, here is what my car did:
No methanol:
With methanol:
Yes, that's a full 7 mph and .4 second difference. 13 rwhp my ass.
We did some tweaking on the tune (added timing in down low) to get it to come out of the hole stronger, and picked up another .15 seconds and 1 mph a week later.
Couldn't agree more on comparing different cars on different dynos. Apples to oranges.
Also agree on running more boost, but only if he actually is cooling the temps down. I'm spraying 14 GPH methanol on 8 pounds of boost, which cools it down perfectly, but most people don't/won't spray that much (for whatever reasoning).
That's what the safety/window switch is for. Fuel and spark tables are setup for meth. So air charge temp is measure post power adder. When the safety switch if made indicating that meth is being sprayed, then timing is run full commanded/tuned advance. When not made, timing is reduced at the ignition box.
As for feasibility... I'll have to try and find a way to explain to my car that what it's doing isn't feasible. o_O
As far as readable HP changes well... I've seen a 13 HP change from just repositioning a car on a dyno. The SAME dyno.
Snow Performance SafeInjection said:
New Improved SafeInjection™- boost/timing reduction system for use with the Boost Cooler® water/methanol injection system promises to revolutionize the industry by providing for safety even with the most aggressive tunes.
The net result of much development and a complete redesign, the new, improved design answers the call for more features and reliability. For years, many have wanted to use water/methanol injection but have not taken advantage of the power increases due to safety concerns. Designed as an add-on to the Boost Cooler® water/methanol injection system, SafeInjection® allows for a safe tune in those instances where no injection is present and an aggressive tune is utilized. With the upgrades listed below, SafeInjection® can drop boost pressure in supercharged or turbocharged applications, or cut ignition timing advance for those with aftermarket ignition systems. "Water/methanol injection is great and our systems are engineered for reliability, but in the case where you run out of fluid with an aggressive tune, many want the peace of mind that this system provides.” says Matt Snow of Snow Performance. The new and improved unit has these important features:
1. Fully adjustable alarm set point with new electronics for versatility.
2. Retard Timing- detailed instructions on integrating with MSD, J&S Safeguard, & other popular aftermarket ignitions.
3. Optional Solenoids to open waste gates or bypass valves to reduce boost.
4. Faster response time and can display real time flow in ml/min (with optional gauge).
5. Overflow alarm for leak detection.
6. Completely new internals for robustness and higher function.
Benefits:
• Ability to run extreme tunes and high boost with safety.
• Automatically warns driver and/or reduces boost or timing if fluid flow insufficient.
As always... There's more than one way to skin any cat. :)
To the OP... Have your tuner explain to you why he does things the way that he does them until you either understand his rational find a fatal flaw in his method.
...but it still doesn't tell a stock ECM to adjust the timing or fuel...
...On a stock computer that doesn't accept external inputs (i.e. flow meters, etc.), there is only one way to properly tune methanol (and the IAT sensor HAS to accurately read the actual temps coming into the motor):
I don't claim to know everything, but I do not know of any way to signal the stock ECM of a 96-04 4.6 Mustang with that switch. Is there some way to jerry-rig it up? Eh, you might could do some soldering on some wires in the ECM, but I'm not aware of any way to do that. The method I explained earlier works in the same way except with fewer components to fail. Plus, I'm not aware of any way to adjust the AFR either.
If you have an aftermarket ignition that is controlled by a safety switch like that, and it works, then great. More power to ya. If you don't, I'll bet you'll be pulling a piston or rod out of your motor that looks like the one I posted above, sooner or later. ;)
Oh yea, they fluctuate. But the one I've been on has read 335, 336, and 340, on 3 separate days separated by over a year.
I think you may have misunderstood what I was saying. I was saying my car picked up 13 rwhp on the methanol, but gained 7 mph at the track, which is WAY more than 13 rwhp. Probably more like 75 (which is similar to your 80), but it just doesn't show it on the dyno like your car does.
