im not really sure where to go from this point so i decided why not give this a try, maybe someone might have a clever idea. i have an 83 fox that i just put a new 2 core aluminum rad in as well as a new water pump. the motor is a carbureted 306 with a comp cam edelbrock heads an edelbrock intake and a holley spread bore. before the aluminum rad and water pump i had an stock 2 core radiator and a new water pump that was spinning the wrong way (the guys before me put a reverse rotation pump on a v belt system lol) anyways, i can't get the car up to temp and I'm not really sure where to go from here. at idle it'll eventually get up there but driving around it just won't. is it possible the rad is cooling too much? do i need a thermostat with a higher rating? mines rated at 180 degrees right now, and it was new about two months or so ago. I'm just not sure where to go from here.
