Car Won't Get Up To Operating Temp
AdrianM
im not really sure where to go from this point so i decided why not give this a try, maybe someone might have a clever idea. i have an 83 fox that i just put a new 2 core aluminum rad in as well as a new water pump. the motor is a carbureted 306 with a comp cam edelbrock heads an edelbrock intake and a holley spread bore. before the aluminum rad and water pump i had an stock 2 core radiator and a new water pump that was spinning the wrong way (the guys before me put a reverse rotation pump on a v belt system lol) anyways, i can't get the car up to temp and I'm not really sure where to go from here. at idle it'll eventually get up there but driving around it just won't. is it possible the rad is cooling too much? do i need a thermostat with a higher rating? mines rated at 180 degrees right now, and it was new about two months or so ago. I'm just not sure where to go from here.
More than likely, your new thermostat is stuck open. Replace it w/ a new one, and you'll probably be good to go.
If that does not do it, what gauge are you using? Cleaning the connectors at the sender changed the reading range in my dash, and a poor ground can peg all of them out. I hope Someone has posted the right multi meter readings.
To check out if the reading is close, you can use an infrared thermometer, a candy/cooking thermometer actually in the radiator, or a mechanical gauge. If you use your meat thermometer, remove the radiator cap cold so you do not get sprayed with hot antifreeze! You should be able to see a big difference in flow from a closed thermostat to when it opens up at temp.
I like the balanced flow design thermostats like the picture. Robert Shaw sold them first in the area, but I see others copy or repackage them. It is supposed to have better open flow and not close under high RPM.
i have an new autometer sort comp 2 water gauge. i know it works and i know its accurate cause I've used one of those laser temp guns and its showed the same temp.
Your computer (unless tuned) will appreciate the factory rated thermostat. I am not sure it will go into closed loop with the cooler one, especially if the thermostat is not working.
Carb motor no computer, but still, I would think that the 195 is the way to go. If you're really hung up on your tstat you can put it in a pot of hot water abd verify it opens up but honestly by the time you've done that you may as well have purchased a new one.
Reactions: a91what
I put in the new 197(lol Ford) degree thermostat I got right from the Ford dealership. Costed me 27 bucks...yay canadian prices :fuss: But it seems to be working so far. I didn't get much driving in today as I only went a distance but it got up higher than it has since the new rad/ water pump etc. I think my old thermostat was opening too soon, I guess that's what happens when you buy a quality part compared to a 6 dollar thermostat. I'm gonna check back in a couple days to confirm its fixed
Just curious, why the 195° the way to go? Heat transfer better or something else? Been doing a lot of research into this and like to hear others opinions.
Higher temp your motor is running at means the fuel is burning a little more efficiently = better mpg and better emissions, but if your motor runs a little cooler I believe you have a little bit more power. That's just my two cents anyways. It doesn't matter to me if a lose a couple ponies as long as my car is running good and I don't have any issues
