At least as best as I can figure for now Steve, these are the main things I'll be doing:Hmm. Dave can we get a parts rundown on what you were thinking for the engine?
Soo were thinking 4.2l stroker mpx build huh.... you sir are going to hurt alot of v8 feelings..... I say an easy 400 400 conservatively....At least as best as I can figure for now Steve, these are the main things I'll be doing:
- Starting with the supercharger I'm thinking the MPx case, inlet tube and hat. Plus a rebuilding of the nose and maybe a coating of the rotors. An 85mm throttle body too. The supercharger will be the priciest section of the engine.
- The heads will be sent off to Tom Morana for an extensive porting, stronger springs, and possibly larger valves (though i'm not sure if this mod would be of any benefit for me). Essentially they will be like getting new aluminum performance heads. About the same cost too, roughly $1500.
- The block will be sent out to be dipped, sonically checked for integrity. At least honed, but maybe a slight overbore.....~.020ish? I'll have the lifter bores checked as well.
- The rotating assembly will probably be entirely replaced. I'm going with a 4.2 liter late '90's F150 crank, forged rods and a set of forged pistons that I haven't really give a lot of thought to yet, not sure who would be best.
- A slightly more aggressive cam too.
- Of course I'll need things like larger injectors, ARP fasteners, etc, etc, etc, and lots more etc's.
This list goes on and on Steve, I'm picturing I'll end up spending at least crate money engine prices in the end.
I'll also be going through Ron Francis for a custom wiring harness. Then there's the whole computer system to run it, you'll be hearing from me in depth when that time comes.
Kind of what I was thinking Steve. This should be fun.Soo were thinking 4.2l stroker mpx build huh.... you sir are going to hurt alot of v8 feelings..... I say an easy 400 400 conservatively....
I'll reuse what I can of the sc's edis system, but yes, it will be edis.Are you going edis with this setup dave?
Edit: I’m sure you have seen it-but I’ve been researching 4.2 rebuilds since my faithful old F150 developed a slight ‘Knock’ lol. But this site has lots of info/parts-http://supersixmotorsports.com/
If you buy what I want you to for this build.... you will not use edis, you will use LS coil near plug or equivalent with sequential spark and fuel.I'll reuse what I can of the sc's edis system, but yes, it will be edis.
I've been looking through that site periodically too Chris.
Send me to a site that I can read up on it Steve.If you buy what I want you to for this build.... you will not use edis, you will use LS coil near plug or equivalent with sequential spark and fuel.
Ok Steve, so this $1600 computer will control basically anything i want to do, am I right?Go here and read up... Will need to build your own harness or send It to me and I will build it for you.
https://www.diyautotune.com/shop/mspro-efi-ems/ms3pro/
This thing will do everything.... it's about 100x faster and has 20x the capability of the one I use.
I can build you anything you want.... or Mike can do it for you since he offered...Ok Steve, so this $1600 computer will control basically anything i want to do, am I right?
Let's say I want PNP, where do I get the hardware part of that?
I'm a bit of a fan of Ron Francis for the actual wiring harness, what do you think?
The M90 does not run coolant through it. It has an intercooler, that's it. I'm not sure about a heat soak problem.Question. How does that SC setup do with heat soak versus say a KB 302? Does the M90 run coolant through it at all? Ive never read up on it to know how it stays cool enough to be a factory option, versus KB's dying off from a subpar rap on pushrod V8s.
I prefer SCOOT'N SCUBY.......... with a 400+ kick. ROCK'N ROBBY!.
