I'd also like to point out that my engine issue might not have had anything to do with the turbo... I think it had everything to do with the guy who slapped it all together and thought he knew what he was doing!
And you hit the nail on the head......I was trending towards turning it up, and up.Mike, I definitely understand the point you're trying to make, but you were also trending towards turning it up and up and... Why not just keep it at a lower, reasonable PSI and let it alone? I'm just worried you're going to put yourself through all the work to make it NA and then despise it. Then you'd have to re purchase everything and do it all over.
If I'm wrong after you drive it NA, so be it. Then sell the parts.
22 psi didn't help,...I'll guarantee you.I'd also like to point out that my engine issue might not have had anything to do with the turbo... I think it had everything to do with the guy who slapped it all together and thought he knew what he was doing!
Mike I think individual runners for each TB would perform the best and give some runner length, no common plenum. You can then tap each runner as stated above and hard line them to a vacuum resorvoir, this will act as a damper for the the map signal so to smooth the pulses.
A common plenum will give you 0 zilch nada for runner length and hugely effect the low speed torque output methinks
Nothing I can do to stop it....I got nothin to work with.Sparing Mike the agony of his thread falling to page two.
Nothing I can do to stop it....I got nothin to work with.![]()
Hah,....and Noobz said it was dumb...First of all, the name. Friggin awesome.
Secondly, I know the feeling. Its been below zero for two straight weeks. Ive had zero motivation to be out finding the solution to my problem, and have no $ for any more new parts. My thread is probably on page 4 or 5 by now.
Yes.Sonic Auto being the parent company of said dealerships?
