You'll know soon enough I guess. It doesn't matter really. Granted, It would be great if it has forged internals, but it'll be just as capable if it has a cast rotating assy in it. Way back when,..... when the majority of the contingency here were still dreaming of owning their first Mustangs (91) A forged stroker assy for a 351w was not cheap. At least not like it is now. If you wanted a 393/408 the cast steel SCAT crank was way more affordable than a forged one, ( and IIRC, forgings were few and far between,...with only a few premium label companies even offering one) I was driving the Black and white Zep back then, and it had a 357/c4 in it. I wanted a stroker engine for the car back then, and the crank was just too much money,...even the cast one.
W/ World Sr. heads that car would only run a 12.0 1/4 mile N/A, but once it had nitrous on it the car ran high 10's... But Again, Iron World SR heads, a cobbled together ntirous system, a Victor jr intake, and a 3310 vacuum secondary carburetor compared to what followed at that time only a few years later(95) there were several other guys running better heads, better induction, and a real nitrous system that were going way faster on the same sized engine. (6.15-20's 1/8 miles, 9.50-9.60 1/4 miles)
(I had a couple of BBF cars during that time that ran close to that with almost stupidly stock configuration, but butt-loads of nitrous..They all eventually failed,.......gloriously)
It took ten years between that one, and the next one that was a Windsor build for me to actually pony up and buy my first stroker kit, but in 01'- 03 I ran that white and purple Mitsubishi Starion that was my last sig line. That car was an alcohol injected TFS R headed, cast crank 393 with a fogger system set at 250, That car ran 5.80 1/8th miles. (9.0 1/4) I broke that block at that power level.
The moral to my Easter ramble is that Even if it is a 351, with those heads that you pictured, and that fogger, it'll be stupidly fast if you want it to be. If it's a bigger engine (in any configuration) all the better, but not the end of the world.
