I know what you meant Willis....What I meant is that I am not envious of the amount of labor he is having to put forth. His end products for each job make me envious though.
Chassis support, or we could call it a web support? Or we could call it Henry?What is a "CS"?
I assume you are referring to your matrix style SF connector as a "chassis support?"Chassis support, or we could call it a web support? Or we could call it Henry?
YesI assume you are referring to your matrix style SF connector as a "chassis support?"
You're just creating names for parts of your car that you have built then?
And "Chassis Support" is the best you can do on a car you call booger?
Yes sir John, seam sealer across the top.The rocker chip guard is a nice touch.
Is there any possibility of moisture ingress on the top side of the open ends that will face the frame rail? I'm assuming you won't be able to get that area with a welder since there is paint all the way to the edge. Seam sealer?
What I wanna know is, How are you gonna keep your pretty green paint "pretty" when you apply the heat that welding's gonna generate?Yes sir John, seam sealer across the top.
I understand what you're thinking Mike. The strength of the rocker pinch weld area is the pinch weld itself though.What I wanna know is, How are you gonna keep your pretty green paint "pretty" when you apply the heat that welding's gonna generate?
And...doesnt it make sense that if you're gonna over-engineer the hell out of that chassis support, aren't you cheating your design by not welding the jacking rail against the floor at the top, or spot welding through the floor on top of it?
How are you gonna get the top of the rail that isp
Seems like a bulldozer with pinto engine kinda thing.
Slight delay on everything. I'll explain later. No choice.I need a new signature line, so:
Dave I miss seeing your Booger.
you may have to do better than that.I need a new signature line, so:
