I worked on Booger today. I got to get him back on wheels to get ready for the big move.
I started by dragging the K-member back under the front end. I had decided to remove a coil or two from the springs just to make putting it back together to move easier. I started with 1.5 coils.
That wasn't enough, with me and my boys sitting on the front end we still couldn't get the strut bolted back on. So off came another 1.5 coils.
This worked. It's a little much even, but who cares? It's just for temporary mobility.
So I got the small crap done, brake booster, pedal assembly and steering column boot, shaft and column, and I also bolted down the driver's seat. This is the first time Booger has had a third pedal! Pretty exciting, eh?
BTW, this is the first time I sat in Booger with the reconditioned seats and a steering column. I'll need to be a bit lower or I'll have to drive in the winter with the t-top off, lol.
That took maybe a little over an hour.
Next on the list is the IRS. I figured out a way to drag it under the vehicle by myself.
Now I have a question for you IRS guys (Chris, Scott, Nick, anyone?) Do you suppose to move Booger out of the garage I could just get away with doing the side mounts through the frame with no additional support or bracing? I also don't want to do the bottom bolts right now.
Hopefully the money pit (I mean my house) sells quick, it's officially listed. I wish to go on to the next chapter of life. This one sucked and lasted way longer than it should have.
