Progress Thread 95 2-Top Cobra Build Thread- Never ending
I vote for the 373 excuse but I feel that the ring and 'opinion' is not the problem, although I feel that is an acceptable amount of play it may be on the extreme end of acceptable.
Typo Fixed. I might be stingy on the amount of play, I went under the 94 coupe and there was no where near as much. I can avoid the knock noise by driving carefully but I wonder if it’s actually detrimental to the drive line.
Yeah it likely ain't do'n the ring and 'opinion' any good but it could last a long time if you are kind to it.
I have a spare in the vert parts car and I believe it has the 3.25 gear in it. Oh, wait, never mind, wrong year.
Finally figured out my steering wheel slop. Inner tie rods were absolutely shot. Rack could use replacing as its leaky but fine for now. The tie rods were super loose and quite frankly dangerous. Replaced the inner and outer tie rods and got it aligned. The car drives like a proper sports car now. In addition I figured I would see if my distributor loosened up to bump the timing. Some Pb blaster and a chisel and hammer allowed me to forcefully move the dizzy and get 12 degrees in. My car was running about 4 previously. The car pulls much harder past 3k where it use to run out of breath. Between the power bump and the new tight steering, I enjoy driving it that much more.
Reactions: General karthief
And my new project for the summer before school is to start painting. We bought a c4 vette in ruby red metallic that needs some paint work on the bumpers. I also want to repair and paint my wing and front fender. Got the compressor and a hf purple gun and all the necessary supplies. Should be spraying next week. Conditions are less than ideal but I’m optimistic for results
Test panel
And the vette project after a compound/polish/wax for those who care. Going to paint the bumpers on it
Fuel door and wing primed. Going to fill little dimples with some spot putty and give it another two coats of primer. Base coat should be here next week. And for all the paint guys, will medium hardener be okay for Florida weather? They sent me medium instead of slow and they don’t do returns and I’m in almost $100 for my clear
pics
Sprayed 2k primer on wing and fuel door. Wondering what these bubbles are that came up While drying. Haven’t sanded yet but worried that I’ll have to redo it. See last pic
Anytime you have something bubbling, the only proper way to fix it is to strip the area and start fresh. Otherwise your going to end up wasting all the material and time you put on it after that.
I did my wet sanding just to see and they disappeared. My primer calls for 220-500. Should I still strip it and start over?
