After that most are to wide. Foxbody 8.8 usually sells for cheap and you might luck out and get one with gears already installed.Those are the only 3?
Facebook marketplace or Craigslist’s. I picked up an 8.8 with 3.73s just yesterday for $250.Alright I will keep my eyes open for those cars in the junk years then. Thanks again SorsCode were a real help for the swap and if I need some more help I will post here again.
V6 and V8 use the same alternator.Well looks like I am back today. I have a question about the difference between alternators for the v6 and v8 I thought they were the same 12v 130 amp. But looking at the back of the v8 on it has a 10 when the v6 has an 12. The v6 one looks like it has been more recently rebuilt as the brushes are much longer than the v8. When I put both of them on the car the 8v one charges better that the v6 that I don’t even think it did anything really. I want to use one of the alternators for a school project electric motor conversion but want to know what one is better to use. Should I take the brushes from the rebuilt one and put it on the v8 10volt one?
Since it was rebuilt who knows. I’m still running the v6 one on mine. Check pulley size, I got one that hand an under drive pulley on it, replaced with a factory one and all was back to normal.Huh wonder why the other one has a 10 and not a 12 on the back of the shell. Should I just swap the brushes over to the older one? Aren’t they the only wear item in the alternator? Just wondering why the more worn v8 one works better than the newer rebuilt v6 one.
Any info on whether a 95 mustang v6 automatic transmission will easily fit a 94 gt 5.0? Are they the same? Thx for any info and direction here.To LS swap a V6 Mustang, there is an entire internet of information, to 302 swap a V6 Mustang, it's basically just sorscode.com. Yes, he did the swap himself, and documented it like a good Samaritan.
Kurt
Take it you didn’t view my siteAny info on whether a 95 mustang v6 automatic transmission will easily fit a 94 gt 5.0? Are they the same? Thx for any info and direction here.
Sorry, having one heck of a time navigating the site here. New byTake it you didn’t view my site
It’s listed under Bellhousing, “If AOD-E you can just reuse the auto from the v6.”
Let me know if you have any questions.
Damn can't find it..Sorry, having one heck of a time navigating the site here. New by
But thx
Ok, got it.you don't see the link under his username?
sorscode.com
www.sorscode.com
The T5 is slightly different between the v6 and v8 gear ratio wise.Ok, got it.
The 94-95 5.0L Bellhosing is unique, so you will need one. You can reuse the T5 if 5spd. If AOD-E you can just reuse the auto from the v6.
Are the 3.8 v6 and 5.0 v8 the exact same transmission, sounds like an exact fit on my 94 5.0, but are they weaker trannys, as someone commented.
Have a chance at a tranny from both a v6 and v8, but they want 3x the $ for the v8...
I'd take the chance if they are the same. Don't want to overwhelm the v6 tranny with the 5.0 v8.
Not to mention some autos in 5.0 v8s get trashed by the extra hp..
That's great, same performance, fit and no modifications necessary. I like it simple.The T5 is slightly different between the v6 and v8 gear ratio wise.
The AODE are the same between the two.
I would, cheap insurance.That's great, same performance, fit and no modifications necessary. I like it simple.
One other question..
I don't know if the lines are pinched off with the fluid still in, but makes sense to do a filter and clean before I install?
The shorter brushes just have more miles on them and are worn down moreWell looks like I am back today. I have a question about the difference between alternators for the v6 and v8 I thought they were the same 12v 130 amp. But looking at the back of the v8 on it has a 10 when the v6 has an 12. The v6 one looks like it has been more recently rebuilt as the brushes are much longer than the v8. When I put both of them on the car the 8v one charges better that the v6 that I don’t even think it did anything really. I want to use one of the alternators for a school project electric motor conversion but want to know what one is better to use. Should I take the brushes from the rebuilt one and put it on the v8 10volt one?
