the paint codes are MK ZH = Twilight Blue Metallic Clearcoat/Titanium lower, the car was originally not all white but 2 tone....
I didn't even use your damn list. I've been doing this every day all day for the past 37 years. I only realized I fixed its A9l a couple days ago, when I put it my 89 and it worked, so have been dealing w this no start since then, not a week ago.
I am the creator of the list and I am 74 years old. I have been fixing cars for 56 years and 28 years of that time has been EFI Foxbody 5.0's.I didn't even use your damn list. I've been doing this every day all day for the past 37 years. I only realized I fixed its A9l a couple days ago, when I put it my 89 and it worked, so have been dealing w this no start since then, not a week ago.
I am certainly glad you got it fixed.The car is fixed, just took it for its 1st test drive. It did great. The only problem now is the alt is not charging.
Its done, just when I was needing a 2nd person a neighbor stopped by !! I was hoping the hinge repair would completely close the gap I have between the front of the upper door frame and door body gasket but it didn't......What's the fix? Tweaking the window frame somehow?Easy big fella ....Go do your door hinge and tell us how you do. Thats a level five repair and takes a special kind of man
No I ground the top of the pin off and drove it down and out for the top one. On the bottom one once it was driven down some, ground the ridge off the bottom and drove it up.So you popped a hinge in that quick...Did you dremel it and just put a new one with no problems
