this is the last time i will do this. i will break down the cost of both 4.6 and 5.0 to achieve an approximate 300rwhp. for arguments sake i will start with 96-98 and a 94-95.
94-95:
heads--$1300, afr 165
cam--$170, tfs1
intake--$470, trick flow track heat
headers--$375, bbk
h-pipe--$180, bbk
catback--$470, magnaflow
pullies--$140, bbk
maf--$275, pro-m
inj--$275, frpp
cai--$155, bbk
$3810
96-98
heads--$1300, patiot stg2 PI
intake--$200, frpp PI intake
cams--$550, comp
headers--$500, bbk
h-pipe--$180, bbk
pullies--$140, bbk
maf--$275, pro-m
inj--$275, frpp
cai--$175, bbk
$4065
of course gaskets and bolts and stuff wil be about equal as well so i did not list them. yes there will be some on here that say that you can do the 5.0 for less than what i listed--that argument goes both ways so shut it. if anything, with all that is listed i feel the 4.6 may make a bit more peak power due to the fact it is a 96-98 and they receive a good jump in compression with a PI head swap(the heads listed also have better flow numbers than the afr's). i also did not add the price of a timing chain or balancer for the 5.0--which it will need most likely(again argument can go both ways).
BTW, i personally feel that one is not harder to work on than the other.
94-95:
cam--$170, tfs1
headers--$375, bbk
h-pipe--$180, bbk
pullies--$140, bbk
maf--$275, pro-m
inj--$275, frpp
cai--$155, bbk
$3810
96-98
cams--$550, comp
headers--$500, bbk
h-pipe--$180, bbk
pullies--$140, bbk
maf--$275, pro-m
inj--$275, frpp
cai--$175, bbk
$4065
...I paid like 135 shipped new from summit 5yrs ago.This is a good break down. The only thing i would add is that on a 5.0 it's not necessary to go out and buy top of the line $1300 heads or a $470 intake. With the number of 5.0L engines that ford has churned out, you can easily go to a salvage yard and score a set of GT40p's and a gt40(explorer) u/l intake for about 400 total. Sure you won't get quite as much power as the afr's but with a good port job and additional bolt on's its still a very significant gain over stock, and for 1/3rd the cost.
yes there will be some on here that say that you can do the 5.0 for less than what i listed--that argument goes both ways.
Hey Ben
That break down was Great![]()
The biggest gripe I got about the mod motors is their lack of low end torque.
I've yet to drive a NA 2 or 4 cam version that did not make me so very thankful I got a push rod power plant in my 95. I've driven several 2 cams, a good friends 99 Cobra many times and the 05 stick GT right after they came out.
Every one of them ... you waited and waited for the power to come on![]()
Finally ... around 4K ... there it was.
The Cobra had lots of it to be sure ... but you had to wait for it to appear![]()
It would be interesting to have dyno pulls of two similar combos of each type like you listed above. I'd love to be able to see them side by side on the same chart.
I can't help but wonder if the same torque curves would be evident but just at higher levels![]()
Grady
Did some digging...I figured you would have some similar 5.0 graphs to toss up for comparison...
cammed, stock head PI
stock cam, LT, stg 2 ported heads
