Hello New Guy On Line
I currently have 24 lb EV6 Ford Racing injectors installed with a matched PRO-M MAF. I want to move up to the EV6 34lb injectors, But I can not find a Matching MAF? The closest is a BBK 30lb MAF 76mm. A couple questions.
1. will the 4 lbs difference in injector and MAF reduce performance?
2. If it does is there a MAF 34lb 76 mm out there to buy?
3. Does any one make a custom MAF ?
I am new to this forum i hope i this is a good question, looking at huge injectors what do these folks do?
Thanks
Welcome to the forums, I've moved your post to an appropriate forum where you'll get more response. I will step up and say you will gain zero by swapping to bigger injectors unless you're maxing out your current injectors
whats the rest of your combo?
BBK cold air fender intake76 mm MAF, 75mm throttle body, underdrive pullys, BBK x pipes, Cat back, 24lb injectors, 155 fuel pump steeda triax shifter, steeda strut tower brace. 373 gears
I bought my Mustang New in 1990 ordered it Twilght blue white top and white leather the car has 56k miles garage kept. The car has been All stock until last year Just got it repainted from the Ford dealer I bought it from. I started to add stuff this year.
