Too bad you did not plan a fuse/relay box before starting the wire hiding.
just gonna stick with the oem fuse box. I thought about doing an 94 style fuse box but didn’t want to over complicate things. I am trying to avoid going too far with this
Wait.. what?just gonna stick with the oem fuse box. I thought about doing an 94 style fuse box but didn’t want to over complicate things. I am trying to avoid going too far with this
I meant just an aux location with a nice cover to hide stuff out under the hood without going into a fender. Not an entire electrical system surgery.just gonna stick with the oem fuse box. I thought about doing an 94 style fuse box but didn’t want to over complicate things. I am trying to avoid going too far with this
If you run that headlight harness inside the top of the radiator support, it will disappear too. Just sayin.... I know you don’t want to go too far. LolOk. After sleeping on it, here’s where I’ll mount the starter relay.
out of sight, but I can still access it if I need to jump it or replace it. Car will never be driven in the rain, so shouldn’t be an issue here.
also got my alt fuse. Likely will install on same location on other side
Reloomed and installed the headlight harness. Just need a few misc things and some small wire to wire up the starter relay and the car is almost fully wired.
I want to prime the fuel system and check for leaks, as well as blimp the starter over to make sure that all works.
I am sure it does, but will check before supper.Does it do it if the engine is not running? Just turn the key to RUN and press the defrost button.
mine doesn’t come on (it used to) but not sure if the engine needs to be running. I could go dig the wiring diagram out and check.
I have a couple small “glitches”. One is the defrost, the other is the BRAKE light doesn’t come on in the dash. With the baer MC there isn’t a provision, but it won’t come on with the parking brake. Bulb in cluster works. Not sure if I need to jumper the old MC plug to get it to work. Again, need to consult the wiring diagram
Key on, engine off, the defroster light is off until the spring loaded paddle is pushed. Then it stays on for a cycle.I am sure it does, but will check before supper.
