Progress Thread She’s a runner
  • Thread starter Thread starter KZGUNS
  • Start date Start date Jul 31, 2019
  • 10
  • 11
  • 12
  • 13
  • 14
  • 38
First Prev 12 of 38 Next Last
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 12, 2020
#221
  • Mar 12, 2020
  • #221
KZGUNS said:
So I took a spring off these heads and also took a k800 to my neighbors friends head shop. The promaxx springs are supposed to be 145 seat pressure and they were 134 ish! The k800 springs were 195!! He thought those were too heavy for my lifters and I tend to agree so I’m gonna look for around 150-155.
Thats odd, mine did not come out that stiff after they were installed. I have 165 on the seat
Reactions: KZGUNS
KZGUNS
I can swing up to 11”
5 Year Member
Jul 23, 2018
1,002
588
133
chardon, Ohio
Mar 12, 2020
#222
  • Mar 12, 2020
  • #222
I know! They’re supposed to be 165. I emailed k-motion to let them know. It’s possible someone returned the “wrong” ones to summit and then summit threw em back on the shelf without knowing. I’m glad I tested them. He even checked his equipment twice while I was there to make sure the number was right.
KZGUNS
5 Year Member
Jul 23, 2018
1,002
588
133
chardon, Ohio
Mar 12, 2020
#223
  • Mar 12, 2020
  • #223
Were yours packed in newspaper?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 12, 2020
#224
  • Mar 12, 2020
  • #224
It has been so long I am not sure. I want to say no..
Reactions: KZGUNS
KZGUNS
5 Year Member
Jul 23, 2018
1,002
588
133
chardon, Ohio
Mar 18, 2020
#225
  • Mar 18, 2020
  • #225
Finally moving forward. After searching for a spring that will fit these heads, primarily the seals I settled on TFS 16315 with a 60 thou. shim, 1.740 installed height. I calculated coil bind and am withing the safe range, i also called TFS and they agreed it would be fine with my combo. My seat pressure will be around 155-158.
K-motion is aware of the high seat pressure we measured and thinks something got swapped etc but will look into it, they also agreed that with my stock lifters and E cam i should look for a bit lighter spring than the k-800. So hopefully I'm good and can get things put back together and get back to tuning!!
Reactions: a91what, Olivethefet and General karthief
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 18, 2020
#226
  • Mar 18, 2020
  • #226
I had no issue with stock lifters and the K800 springs but i am now using link lifters so i dont worry about it.
Reactions: KZGUNS
KZGUNS
5 Year Member
Jul 23, 2018
1,002
588
133
chardon, Ohio
Mar 18, 2020
#227
  • Mar 18, 2020
  • #227
Ya I’m not implying they aren’t right for your engine. I’m just trying to not take this apart again lol
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 18, 2020
#228
  • Mar 18, 2020
  • #228
No worries, I deferred to the cam builder for the springs. My cam lobes are rather aggressive or so he says
Reactions: KZGUNS
KZGUNS
5 Year Member
Jul 23, 2018
1,002
588
133
chardon, Ohio
Mar 27, 2020
#229
  • Mar 27, 2020
  • #229
Maling some progress. While working from home i had some time to finish up the valve springs and get everything adjusted I also tweeked a couple guides to get a better contact for the roller. I'll say this, dont buy comp cams rollers. They have way too much lateral play for my liking. I almost went out and bought diff. rockers. I also swapped out one of my idler pulleys for a bigger one to push the belt more under the SC pulley, it may help with some slippage.
Reactions: Olivethefet
96pushrod
I think they're a little easier to get off
5 Year Member
May 15, 2018
1,530
872
133
Savannah
Mar 27, 2020
#230
  • Mar 27, 2020
  • #230
Honestly after I just had a set of the trickflow springs the bed after 10,000 miles I would think again before buying their springs.
I really don’t know your cam specs though, so maybe you’ll be fine. If it’s anything even moderately aggressive I would pony up the cash for a 1200 series spring from PAC
Reactions: KZGUNS
KZGUNS
5 Year Member
Jul 23, 2018
1,002
588
133
chardon, Ohio
Mar 27, 2020
#231
  • Mar 27, 2020
  • #231
Its just an e cam so its not overly aggressive. It's all back together so I'll have to take the gamble. It'll be years till i put 10k on it. Hell I'll probably split the block before that lol
96pushrod
5 Year Member
May 15, 2018
1,530
872
133
Savannah
Mar 27, 2020
#232
  • Mar 27, 2020
  • #232
Oh yeah I wouldn’t have any worries with the e cam.
KZGUNS
5 Year Member
Jul 23, 2018
1,002
588
133
chardon, Ohio
Mar 29, 2020
#233
  • Mar 29, 2020
  • #233
can anyone open this log file? for some reason now i cant open any of these mlg files in mlv. MLV is fully up to date as well
  • 2020-03-29_11.21.49.mlg
  • new springs-03-29_11.50.20.msq
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 29, 2020
#234
  • Mar 29, 2020
  • #234
I was able to open the log no problem. you may have to right click the file and tell it to use MLV
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 29, 2020
#235
  • Mar 29, 2020
  • #235
here ya go
  • 2020-03-29_11_modified.msl
Reactions: KZGUNS
KZGUNS
5 Year Member
Jul 23, 2018
1,002
588
133
chardon, Ohio
Mar 30, 2020
#236
  • Mar 30, 2020
  • #236
I'm probably the only one with this issue lol but you can change logging preferences from MLG to MSL under the options menu. It still doesn't make sense that MGLVHD wouldn't open the MLG file though but at least i can change default to MSL. I sent an email about this issue and will post up what they say when i hear back.
Good news is i was able to adjust my VE and hopfully in the next couple days i can get some time to drive and see if my valve float issue is resolved and i can finish up tuning this ve and move on to the ve table with meth. Praying to the engine gods I'm good!
Reactions: stanglx2002 and Steel1
stanglx2002
CT Material here
1,563
1,110
164
Mar 31, 2020
#237
  • Mar 31, 2020
  • #237
I hear the roads are clear these days sooooo.....
Reactions: KZGUNS and General karthief
KZGUNS
5 Year Member
Jul 23, 2018
1,002
588
133
chardon, Ohio
Mar 31, 2020
#238
  • Mar 31, 2020
  • #238
Hell ya!!!
stanglx2002
CT Material here
1,563
1,110
164
Mar 31, 2020
#239
  • Mar 31, 2020
  • #239
So we will see a video later this afternoon then right ?
KZGUNS
5 Year Member
Jul 23, 2018
1,002
588
133
chardon, Ohio
Mar 31, 2020
#240
  • Mar 31, 2020
  • #240
Ok I had for some reason felt I needed to recheck the timing. I fixed it at 20° and was showing 0° at the crank. I could have sworn I checked this when I fired it after heads etc. This would explain why it felt like it should have more power than it did. Now I’ve got a hanging idle. Grrrr guess I’ll need a session with @a91what to review this again.
Reactions: 90sickfox
  • 10
  • 11
  • 12
  • 13
  • 14
  • 38
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • Locked
SOLD Maximum Motorsports MMTR-2 Bumpsteer Kit - 1979 - 1993 Mustang
  • AeroCoupe
  • Apr 18, 2025
Fox Body Mustangs For Sale (1979-93) Aug 5, 2026
AeroCoupe
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
