So Im buying a car modded 95 5.0 how much is this worth?
\\ J //
Trick flow stage 2 cam
Trick flow heads 2.02 in 1.6 ex
Arp head studs
Trick flow track heat upper and lower intake
Trick flow harden 1.67 push rods
Trick flow roller rockers 1.6
Crane hardened guide plates
Ford motor sport 24# injectors
BBK 70 mm Throttle Body
BBK elbow for 1994 95 conversion intake
C & L hard tube
Pro M Chrome Mass Air 70mm calaberated for 24lbs Injectors
Msd Distributor billet for the 1995 computer controlled
Crane HIgh 6 s with coil and proper plugs
BBK Long tube headers
BBK Off road x - pipe
BBK Upper and lower control arms for rear
1989 Linc on mark 8.8 rear end with 3.73 gears fresh clutches and heavy duty spring w/lsd (now as strong as a 9 " )12" vented disks and new calipers
Griffin Radiator
March Billet pulleys water alt crank
Custom idler Pulleys x 2
Trick flow gaskets kit
as you can see the set up sounds pretty solid
can i get an estimate on how much was spent in parts?
still debating if i should start from a base stang or keep going for this deal and finish it off
it currently has a cobra body kit cobra r's on slicks rear seat delete new suspension everything else is stock
so i know this is worth my $3000 just wondering how much in parts were spent and by any chance can anyone estimate the hp this baby is putting out the owner only knows that he's running 12s on the track easily let me know THANKS!:nice:
