Roush Will a 4" Idler Pulley work on a S II M90
I would try a smaller belt frirst. I am making over 400 rwhp with my S2 and have no issues with slippage. I have had problems before and that was because my belt was too big.
What size of belt are you using? My setup:
'01 S281, Series II Eaton M90, Chicane 66mm pulley, all other pulleys are stock.
Also, do you have an opioion as to belt types? I ask because I have a belt that has diagnolly cut lines in the belt which is supposed to be better for heat dissapation and strength vs. a standard ribbed belt.
Also, what's your setup? I wouildn't mind making 400rwhp....
Thanks!
~ Billy
'01 S281-SC #201
'99 S281-NA Cobra #357
If you are using the stock size belt that is your problem. I have a "Gates" micro V size 1115.
My set up is too long to list. If you are really interested, go to ebay and do a search for item number 4565273618.
Dang! Nice car! We should've got that instead of the Cobra. What's the reserve on the car??
~ Billy
