I'm trying to figure out if the R350s will fit with Eibach Sportlines installed, but I don't know how to make heads or tales of the wheel and spring specs.
Anyone know if these will work either through experience or through math?
https://lmr.com/item/WTK-177916GA/mustang-sve-r350-wheel-tire-kit-bronze-19x10-11-15-17-g2
R350s are 19x10/19x11.
Tires are Nitto NT555 G2 275/305.
Wheel Specs
Front:
Backspace: 6.88"
Offset: +35mm
Weight: 24.4lbs
Rear:
Backspace: 7.97"
Offset: +50mm
Weight: 24.5lbs
https://lmr.com/item/EIB-414535/2015-Mustang-Eibach-Sportline-Lowering-Springs
Front Specs
OE rate: 28 N/mm (160 lbs/in)
SPORTLINE progressive rate: 38 - 58 N/mm (217 - 331 lbs/in)
Bump-stop: New Eibach bump-stop
Damper: OE
Tubing: Yes
OE wheel center to fender: 396 mm (15.6 in)
SPORTLINE wheel center to fender: 357 mm (14.1 in)
SPORTLINE can be aligned to OE Specs: Yes
Front Alignment:
OE Camber = -0.8 deg (+/-0.8 deg)
OE Caster = 7.2 deg (+/-0.8 deg)
OE Toe = 0.00 deg (+/-0.2 deg)
SPORTLINE Camber = -1.2 deg
SPORTLINE Caster = 7.5 deg
SPORTLINE Toe = 0.2 deg
Approximate installation time: 2 hr
Rear Specs
OE rate: 117 N/mm (668 lbs/in)
SPORTLINE progressive rate: 154 - 174 N/mm (879 - 994 lbs/in)
Damper: OE
Tubing: Yes
OE wheel center to fender: 387 mm (15.2 in)
SPORTLINE wheel center to fender: 353 mm (13.9 in)
SPORTLINE can be aligned to OE specs: Yes
Rear Alignment:
OE Camber = -1.2 (+/-0.8 deg)
OE Toe = 0.1 deg. (+/-0.2 deg)
SPORTLINE Camber = -1.6 deg
Wheel Specs
Front:
Backspace: 6.88"
Offset: +35mm
Weight: 24.4lbs
Rear:
Backspace: 7.97"
Offset: +50mm
Weight: 24.5lbs
Front Specs
Damper: OE
Tubing: Yes
Front Alignment:
Rear Specs
Damper: OE
Tubing: Yes
Rear Alignment:
