good to hear,i may be a click away from some deep dish also!....its not on the ground yet,but does it seem like it going to clear everything?....I love it but can't make my final judgement until the car is sitting on the ground
yes it seems that waygood to hear,i may be a click away from some deep dish also!....its not on the ground yet,but does it seem like it going to clear everything?....
stock 90.5 I believeYou are exactly right Jeff. The belt will be close but they won't touch as long as you use the correct length belt
Thanks dude I am hoping you get your car ironed out ASAPThose wheels are gonna look awesome!
I am just shocked man I did tons of searches and you'd figure how many times this has been done someone would have a definitive answer.And dont guess on the belt, run a string around the pulleys
Got the oil feed t all made up and is installed . cut hole for power pipe just need to install the rubber around the hole then that will go in . harness is installed and upper intake is now a permanent fixture .
Need to get a shorter belt because the stock is still laying me on the water pump . so I am gonna try a 87.5 .
need to get the wide band bung In and finish exhaust .
Lug nuts and radiator hold down rubbers will be here Friday so that can be finished up . hoping maybe to start it this weekend .
can't see in the pic you see the smog idler , if you look a pic or two up you'll see it it's a black 3gMaybe the pic doesn't show it but where is the alternator? I know it gets relocated but I don't see it in the pic....or do I?
I tried prob is it's drilled for a alignment hole so that's the only way it fitsHey Jeff anyway to flip the tensioner? i kinda remember mine when my mustang was supercharged being different...i have to see if i can find some old pics...if you go to youtube...look up my85gt i have a video of my mustang when it was supercharged i think you can see under the hood maybe that might help you...
