Build Thread My Never Ending 89 Notch Thread
I just did this myself, my 10 micron was filthy, and took alot more effort to blow through than I was comfortable with. I ended up ordering a Summit labeled 40 micron unit to replace the entire filter housing, because they wouldn't have the 10 micron replacement element till at least 8/4.
So,..100 micron pre, 40 mic post for me too.
Only mine is considerably more cheesebagly than yours I'm gonna venture to say.
I have Aeromotive -10 units in this with the stainless mesh USA filters in them . I figure the 40 post maybe the pump has to work a little less . Maybe it’s negligible but I did it .
You're such an innovator...First its buy a 2 is. Then its put a 40 micron filter after your 100 micron filter..you're like The car Dali LLama.
Sarcasm I like it . I was just saying I did what you had said you did too and replying with the filters I I had used . I had the same issue and I wasn’t comfortable with how much effort it took to get through the 10m . Just some Conversation .
In reality I’m combating a heat issue after long driving I figured maybe it was the pump having to work harder and making it worse . The reality is it’s most likely my s h i t regulator placement is too close to the header and that’s where it’s picking up the heat .
Needs more blow off valve :)
Finally got the 8inch / 6inch asp pulley on to get the water pump back up to speed . Got the contour alternator pulley on . The belt and the tension was a huge issue with the ps relocation on Vortech cars and now even more with the odd pulleys . 83.5Inch belt is way to tight 84Inch was too loose .
The alternator is now adjustable and the 84inch belt works .
Looks like someone likes working on their car more than driving it. That's where I've found myself.
I’ve been busier then work with anything else . From feb to June 1 I probably drove the car close to 2500 miles . Maybe more .
After every few outings I wipe everything down in there. Having everything Powder-coated makes it easier to stay on top of .
From February to june1 I definitely drove my car close to......zero miles. Maybe less.
Reactions: krazedstang
