IM PISSED.
it blew up.
It ran, i fixed the vam, it was running nice, making cool noises, i gave it one good pull and ..... POP AND A
ton of smoke out the back. Engine dies. I pull over, and theres milkshake all over my fender.
What caused this? Well.
1. Me
2. Cylinder head. When I got it back from the machine shop it was almost as if they ran the head through the decking machine too fast, if you dragged your fingernail across it you could feel the ridges from The cutting.
3. Improper boost control.
I had a gauge hooked up, when I did my lighter pulls, from about 20 to 30 mph, it made about 5 to 10 psi of boost, i turned my boost controller all the way out so it made as little boost as possible for now.
The way i have it hooked up may be the issue, instead of getting boost pressure straight from the outlet, its getting it from the tree, more of a delay, i also dont have my blow off valve hooked up, figued the turbo coup didnt have one, why should mine? Atleast for now
One of those three things i mentioned is definitely the cause of the head gasket popping.
Oil in the pan is milkshaked. Im pissed, im gonna go pull my head
