Progress Thread 1989 LX 5.0 convertible - mild project
This is the portion that makes a cable adjustable:
Non-adjustable cables will not have a nut and/or threads at the end where it attaches to the clutch fork.
Worked on getting the interior back together yesterday after replacing the quarter window motors, lift cylinders and some missing stereo equipment. Really cleaned up the trunk and back seat area.
Moved on to installing the Hurst show throw shifter and, after removing everything to get access, I found out that I already have a Pro 5.0 Power Tower shifter! Went to reinstall the rubber boot and one of the clips for the bolt was broken. Jacked up the car and got underneath to hold it while the wife tightened the bolt. Got the new Hurst handle installed and was all done.
The last thing I wanted to do was install the plastic on the door strikers. Drivers side went on just fine. Unbolted the passenger side and .... F*%# ME! The captive nut fell down inside the quarter panel. Guess I'll be taking the back seat and quarter panel back off.
*EDIT: Got it all back together this morning. Thank goodness for my wife's tiny hands! **
I have a stock hood for thd car, and my plan was to do paintless dent removal on the car, have the hood painted to match, and polish the rest of the car while it was at the bodyshop.
I got a quote for PDR and my jaw hit the floor. Luckily, my body guy said he can fix all the dents and paint the car from thd belt line up for a couple hundred dollars more than the PDR quote.
New body molding came with the car. He asked me to remove the old molding, so started working on that today.
We got everything bug the last bit of old glue on the driver's door. Taking a break and letting my fingers recover.
Curious on your PDR quote. I'm a PDR tech,car looks pretty straight to me but pics can be deceiving
The majority of the dents are on the top of the fenders, top of the trunk lid, and one on the sail panel in front of the trunk lid. I think they're are about eight all together.
There are a few on the doors and rear quarters. Only one has any chipped paint, and it's small (maybe 3mm). I think he counted 13 areas in all. He quoted me $3,100 for the PDR.
I need to clean up some dents on my car,I'll hafta' make a before and after with time spent. $3100 is absolutely ridiculous.
My thoughts exactly.
I did pick up a Notchback trunk lid today for $50. One corner has a little bend, but no wrinkles or dents. Instead of dealing with the luggage rack and the dents in the decklid, I think I'll just swap them out.
Man, what a saga this transmision stuff has been!
Here's a thread on the issue: https://stangnet.com/mustang-forums/threads/downshifting-from-3rd-to-2nd-issue.931803/#post-9459412
Even though the shop was convinced it was clutch related, a new clutch didn't fix it. They said the clutch was definitely worn, and the new one feels great. Until the transmission gets hot.
I discussed my options with them and chose to let them rebuild my transmission. That was going to be several hundred dollars cheaper than a new one from LMR. Well, the car got lost in the shuffle waiting for parts and then they lost a tech. It's been more than two weeks and nothing has been done. I talked to them this morning and they were about to pull the transmission to do an inspection. After talking to them about parts availability and timeline, I did what I should have done two weeks ago: I pulled the trigger on a new World Class T-5 from LMR.
Hopefully, this thing will be fixed and back together by the end of the month. The good news is that it will have a brand new clutch, flywheel, and transmission.
I replaced the T-5 in my '86 with a Tremec TKX, which required a new (different) clutch and bell housing. I'm not sure that was the best choice, but it's working and driving.
Bill
