Don't wreck it. It's not like you can get another. I would assume the rear end likes to kick out like a real Mustang does. Even the best of us can get in trouble on slippery pavement. A couple times my heart has stopped as I was sideways.
like a real Mustang
You need a 912A616 Truetrac! They are much better than the clutch type diffs. They are torque sensitive, not differential speed sensitive and they do NOT WEAR! They are 200 bucks more, but worth the money.
BUT you spent a lot of money for the diff, so that you burn two tires at the same time, which cost even more to replace
But good news on the shipping cost side. It seems prices will come back to a normal level for us customers in the next months (at least for diesel powered ships, don't know what captain burnout wants for shipping tires and locker diffs with his ghost sailing ship):
Sorry, but that it not true. TrueTrac is a torsen-sytle diff, that connects both sides with worm gears.The way the Truetrac works is that it will spin either one wheel or the other, depending on the circumstance.
That is completely true. I just want to point out, that beside it is from spirited driving (not drag race) the best solution it dosn't have wear... the clutch type will wear with a lot of burnout actionI think they're both a vast improvement over an open differential
I had one in my 66 Mustang. If you increase throttle opening while driving a corner you can directly feel how more torque is transmitted to the inner rear wheel. For spirited driving it is in my opinion the best option. As described below only if one wheel is in the air you have a problem, but that is more a offroad thing. And you can still get torque transmitted to both wheels, if one is in the air, when you step on the brakes slightly.
In the Mustang S550 the clutch type is the standard LSD, torsen is included in the performance package...
Torsen and helical differentials work in a fairly similar fashion, using clever gearing to apply locking force to transfer torque to the wheel with more grip. They’re great for street use and even light track use, though they do have a disadvantage.![]()
Engineering Explained: The Best Kinds Of Differential And What's Most Suitable For You
What's the difference between open, locked, welded, Torsen, clutch type LSD, electronic, and torque vectoring differentials? There are many options to choose from, so which is the best for your application?www.carthrottle.com
Advantages:
- These differentials begin to send more torque to the slower-rotating wheel the instant there is a speed differential between them. Essentially, it reacts far quicker than a VLSD.
- These are purely mechanical systems, with no routine maintenance required as the differential action is dependent upon friction throughout the gears.
Disadvantages:
Street
- When one wheel is in the air, a Torsen diff acts very similarly to an open differential, and very little torque is sent to the drive axle. For street use this is completely acceptable, but it may be an issue for more purpose built vehicles on the track.
If you’re looking for a differential to help get the power down and prevent one tyre fires, a Torsen or helical differential is a great option for street use. These can be found in the Subaru STI, Toyota GT86, Ford Mustang GT (with performance package), and Mitsubishi Evolution to name a few.
Track
For track use, something more aggressive tends to be a better option, such as a one-way or 1.5-way clutch type LSD.
Drift/Rally
For drifting or rally driving, occasionally a two-way LSD may be the best option, as it’s more desirable in these scenarios for wheel speeds to remain relatively equal.
I'm going from what I've noticed with my truck - it always seems to alternate which wheel spins when I purposely floor it on asphalt in the rain. That coincides with what this guy is talking about in this video that I watched before buying it. So for a burnout or when your wheels are almost freely spinning due to loss of traction, I'd think that the Truetrac would react the same and search for resistance/traction.
