Okay, I would say journal 1 - cyl1&cyl5 are ready. I may get away with first one...
Used 1000 grit paper with WD40 and just a 30-40 soft turns with shoe string to loose lines slightly felt under fingernail.
Measure is 53.917mm or 2.1227" which is a hair below specification minimum (2.1228"). Perfectly round journal, not oval. I used a micron OD micrometer. Can't check con rod ID down there.... :-(
Forgot to measure con rod and journal width, but it will be hard to do it precise down there.....
Waiting for assembly lube from mechanic, throw in new std bearings, tighten to ... middle 22 ft/lbs? (19-24 is spec)
And tomorrow we pray for journal 2...
