Out of everyone here , im probably one of the few here that’s been 7400rpm plus with a tfi no lift shifting lol. I kept mine it’s in the attic because I know it works.TFI Hater!
The Box R comes with that spacer. I need aftermarket fuel rails and will likely need to move my fuel pressure regulator. Curious now what other challenges await on this install.Take a look at the pics in this post as it shows a pretty healthy spacer:
Build Thread Post in thread 'My Never Ending 89 Notch Thread'
Cars been down since April . Changed the oil found a c clip in it which led me to finding it was a c clip from the plunger of my morel short travel lifters.
This is semi my fault as there was some miscommunication between me and the engine builder. The engine was set up as if it were a low lash solid roller when it reality it should’ve just been setup as a hydraulic at zero lash plus a touch of preload. 5 years I haven’t ever checked the lash so I’m thinking this played a part.
So I grabbed a fresh set of head gaskets and some new Johnson short travel lifters for it and it’s almost back...
If it was wider I feel like it would loose the look a bitI really like the Bigs and LIttles.
I will want to do something similar with a wider tire on the front.
I considered the JMS 10 holes at one point with the 15x10 rear in the silverI had to try this just to see what it would look like
