Update. Finally got to put some more miles on it... 35. It cruised around great. However, when I would put it to the floor in first gear it would fall on its face and spit and sputter. Anything up to 3/4 throttle feels fine. If you mash it in a higher gear while cruising it feels pretty good...weird.
Things I have done so far in regards to maintenance:
-Timing is at 11 deg
-New fuel filter
-Fresh fuel
-New autolite 25 plugs gapped at .054"
-New pressure regulator (from AutoZone)
-PCM capacitors
*TPS is at .9 when idling and it appears smooth when I open it with KOEO.
Parts on the way:
-New air intake (stock replica) with K&N filter
-Motorcraft cap, rotor, and coil
It has done this since I got it but until now I didn't really hammer it down in first.
Any thoughts and ideas are appreciated.
-New fuel filter
-Fresh fuel
-PCM capacitors
Parts on the way:
