I currently have Flowmaster 40 series, MAC CAI, MAC u/d pulleys, and 4.10 gears. Now I plan on putting these on sometime in the NEAR future...
Headers
H-pipe
E-cam
Edelbrock RPM II intake
70MM TB w/ spacer
Mass Air 73mm or 76mm
2400 Stall converter
255 fuel pump
Would 30# injectors be over doing it?
Also what would be more suitable a 73mm mass air or a 76mm?
Headers
H-pipe
E-cam
70MM TB w/ spacer
255 fuel pump
). If you plan on buying them be sure to spend the money on dyno tuning at a reputable shop. If your car is running rich with the 30's then your computer does not have the proper tune or some other problem is occuring. 19 LB/HR injectors should be good for now. 24 LB/HR injectors will be more than enough if your stock ones are on their way out. They are what I would upgrade to if I were you.
PM me if anyones interested.
