Build Thread My Never Ending 89 Notch Thread
@TOOLOW91 's REAL dyno readout:
So back when I had underdrive pulleys I did the 3G swap and the alt did not charge well at all . I had asked around and maybe even here . I swapped the fox pulley on . This was never an issue all these years even with the blowers because my crank pulley was still under driven .
Well when I swapped the asp pulley on I had them build it standard sized . I forgot about the alt pulley that I had swapped . Well it over spun I believe .The 200a fuse did its job to an extent . Said the alt was putting out like 36v or some crazy number on my meter . I lost my volt gauge on my way to work yesterday . Thank god the fuse did what it did cuz it saved all the electronics in the car .
Scary stuff .
What a night . Tried to make some test passes and get data again . Track was complete garbage . Tried to roll out and get some wot data . Not even maybe . Track was so bad that it spun every gear .
Try to make another pass car isn't running right . No big deal find the vaccum line blew off the t from the BOV. I zip tie it so it can't slide off and we're golden . Car starts runs fine . Shut it off and close the hood the car just cranks . Start checking things - hit the MSD box and boom fires up . Make another pass do a small burn out get like almost no data . Pedaled it and just tried to roll back in it . No good it spun. I finally got something and it went 126mph still hazing the tire in 4th . I didn't have the 15s on it either because I still haven't gotten 5 Lug wheels yet .
So new msd is ordered. Old one is already boxed up to get sent out for a spare . This msd is 2.5 years in the car . I got it for free from a friend who had it laying in his tool box so I can't knock it.
I believe this was caused by the whole alt over charging issue . It was the first real major hot day too so that was it . Another set back but it is what it is .
On another note on the ride home two gsxr750 caught me in Mexico . And I couldnt help myself . 2 times they both tried me from a roll between like 40-60 and I walked them . Like there front tires were at my rear quarter panel . Even gave them the jump on the second run and still walked them . Talk about fun .
Cars got 8 fresh plugs in it. Msd harness is now GM weather pack connectors on both sides. Built a jumper harness and verified the car will now run with or without the msd !! Never have to worry about being stuck again. Not sure if I want to just send the new box back or keep both and have one as a spare.
Reactions: A5literMan
Throw it away, I was wondering why you bothered with it. Your ecu now finally has control of the coil dwell and the stock coil fires like a madman.
That thing does full sequential ignition doesn't it? If so I would go to coils.
Sorry can't remember what you use for ignition
Stock tfi dist , stock coil , just with an msd box on it
At 17psi I don't think that coil alone is goingto be enough to not have spark blow out issues . I may be wrong . We'll see . Yes it does full sequential , maybe down the road I will go to Ls coils
