I just spent 2 hrs trying to test fit the passenger side of my accufab 1 3/4 long tube headers but I cant even get them up through the K member.
I unbolted the motor mounts from the K member and jacked the engine up as high as it would go, the upper intake was hitting the cowl by the hood and the bolts for the motor mounts were completely out of the holes for the K member and the long tube would still not go up through. I removed the starter to give it more wiggle room and it just will not clear the Team Z K member and the side of the tranny where it sticks out where the starter goes. It keeps getting caught up right at that point. There is no way they will go trough from the top down from what I can see unless maybe taking off the valve covers makes a difference?
Anyway what do you suggest to try and get this to work? I need to test fit these to be sure there is no issue before I send them off to be coated. With no smog or AC I figured this was going to be a breeze but its becoming a major PITA
