Build Thread My Never Ending 89 Notch Thread
So the price has dropped then. :)
When they were made to order, they were considerably more. I have 3 or 4 different ones lying around somewhere. When I got a quote for a just an over sized crank pulley (single belt) it was over $700. :notnice: I'm sure someone has these made and sitting on a shelf by now.
This was a make to order deal as well . I waited almost 3 weeks for it .
I'll have to measure the ones that I have. I dunno if you recall, but the white 89 I have had Vortech kit on it. I have 3 different size pulleys for that thing. I guess that I assumed they were shelf-stock items from Vortech. :shrug:
They are but the renegade pulley only comes from them with an undriven crank acc belt . Kris recommended having asp make the 8 inch blower pulley with the standard acc belt pulley size on it.
Well its been hectic but i managed to work overtime today and get the car completely back together and running. All ineed to do tomorrow is swap the crank pulley, Run a wire from the cluster to the msd for a tach lead.
Tuesday kris is supposed to get it on the rollers. I tried to tuck the harness down and keep it as neat as i could. Ill post some vids in a few.
Reactions: A5literMan
Here's some pics . Everything needs a good bath and to be polished up
Well its official . Got the garage straightened up a little bit. I pulled the cluster after work and fed the tach signal to the stock tach. Thats all up and working. Tomorrow night well have some numbers . I cant wait. Its been a long week to get to this point.
Did you tighten the tach gear and lube the cable?
Reactions: TOOLOW91
Soooooooooooo
We got it all ironed out took it for a ride worked on some stuff a bit with drivability .
Made a full pull and saw 705 at the tire on straight 93 pump gas . Plugs looked good but we all agreed to dial it back a bit seeing 17psi . Played with it and got it down to a safe 639/662 at the tire .
We then spiked the fuel with 5 gall of MS109 .
The car made 740/730 at the tire.
It's wicked .
Dang Jeff, I want to see your car in person.
Maybe someday I'll have a driving fox body:nonono: and make a pilgrimage out east.
Incredible numbers brother. Sooooooo what's the next mod planned?:jester:
Enjoy it . That's the next mod lol .
Eventually get the ac back in it . All it has is a new evap core as of now .
