Build Thread My Never Ending 89 Notch Thread
Started getting some stuff together .
-Black Dual Sync distributor
-Derale fans ( need a little more cfm and speaking to someone with same combo as me this did the trick )
- Motion Raceworks’s billet catch can ( moving it under the hood )
Next will be the NCC Intercooler and the piping but I’m waiting to get paid on a Few little side jobs I have going
Reactions: RaggedGT
90 all polished up and dressed . Intake is going to MCRP end of next week to get opened up and done right . 70 is polished is up for sale on FB as well .
Dang I want an accufab for my car, really want it for the other intake and motor, but wouldn’t mind running it on my Gt40 now, the trickflow intake I was told was a 90, but it’s actually a 75.
Accufab is the only option In my opinion . I have had the other cheap ones . No comparison
Reactions: Monkeybutt2000
2021 poker run yesterday . First place won 800 2nd 230 . I lost but had a blast
Some more
Got the new motion catch can mounted the other day on the driver frame rail . Remade the lines up .
Today after trimming the new fans as much as I could to get the clearance between them and the engine I got it mocked up . I need to radius the spot by the rad hose some more and drill to mount the lower brackets . Once it’s all done and bolts up I’ll make the new harness . Then pull it all apart and have the brackets and shroud powder coated black
That has to be the most sanitary engine bay of a driven car-Ever.... lol.. Good looking fan setup, where you running warm with the old setup?
It’s a little dirty actually lol . Not hot Per say but in the summer like 95 plus degree days it would creep to 200-205 . Someone with a really similar combo swapped to there and said no issues after that . I hope it’s worth it because it’s a lot of work getting them in . If not I’ll go right back to my contours no big deal . I’m keeping everything including the harness for them that I built so it would be fast to go back .
Reactions: RaggedGT
Hey so you said you had your intake widened to run the 90mm acccufab? How or where did you take that to do so? I have the trickflow R series for that 408 build I am slowly doing but it’s a 75 and would like to run the 90 myself.
