Btw - I am going to lower the oil level today to the 5 quarts - too much oil I feel is causing extra work on crank churning more oil
I've told people this till I'm sick of saying it. Good explanation!
I'm 53. Also love this forum especially now days. I don't seem to enjoy the general public any longer because most of them wall around brain dead. Drives me crazy. There's some pretty smart folks on here. Excellent conversations!
So your at the saloon with your wife you lucky dog....... I dont drink, alcoholicI just put 5qts in mine and marked the dipstick.
Oh, and I just turned 56. This is the third Fox I've owned. Drove the first two off the lot at the dealerships brand new. I get smacked by the wife too if she's along and I show off a little. She does like cruising with me though.
Here's a picture from the Full Throttle Saloon in Sturgis SD last week, at the Mustang Rally with some of the other cars in our club.
Oh yeah. We both have a good time at the Rally. We even met Micheal Ballard, owner and lead singer for Jackyl! The Mustang Rally isn't anything like the bike Rally, there were over 600 cars there though. That's the wife and I on the far right.So your at the saloon with you wife you lucky dog.???
Drained a quart and changed the pvc and crank screen filter ( the screen filter was totally clogged so it a noticeable change , seems to idle smoother )
Beg to differ there, Kurt, though you're right about your SN95. Fox senders were better than switches, but still suck and not to be trusted:
Did you take the upper intake off? If not, how did you get to the PCV and screen?? I've wanted to do this, but I don't want the hassle of taking the upper intake off.
That pic makes it look much easier to get to than it is on mine.....PCV and screen are in the lower, not upper. No need to remove anything.
Well, LMR shows a new sending unit in 90 and a new one in 94. I think all fox oil pressure senders are variable. The only sub '90 I've owned was an '89. All of mine have varied. My '93 varies. The '91 I just sold varied quite a bit. There is a low threshold where you can see it suddenly switches to nothing on the gauge, though.Yeah poop, you are right. I forgot they used to have real gauges on some of the Foxes. I forget what year they switched.
Kurt
I'm gigantic and I can get to it just by leaning over the fender and reaching back there so a normal size dude should have no problem. You asked did the intake have to come off. Never heard anybody do that just for a PCV valve change. Follow the vacuum line with your hand to the valve and remove it. Pull the grommet out and the screen is right under it. Maximum 5-10 minutes.That pic makes it look much easier to get to than it is on mine.....
Yep. When my car started using more oil than I could afford I changed to this oil 10w40. Truth is it's probably just as good as anything else and only $12 for a 5qt jug.Walmart Oil the cheapest you can find and your good with your 110k milege all original 5.0 10/ 40 or 20/50...
