It was easier to hammer it in that wayIt's upside down!!!!
Don't count. Brand loyalty and all.It was easier to hammer it in that way
It was nice to have the plug n play feature, at least somewhat. I looked into a cam sensor from msd as well and using a trigger wheel. This just seemed easier.The cas works well. I just use the stock shutter wheel and a hall sensor to make my own.
Vs7875. T4 flange 1.25ar with a divided housing. Should spool fairly quickly. Only plan on pushing around 8-10 lbs on 93.Details on the turbo?
InitiallyVs7875. T4 flange 1.25ar with a divided housing. Should spool fairly quickly. Only plan on pushing around 8-10 lbs on 93.
Get out of my thoughts lol.Initially
Water Methanol and you can tweak the percentages for the additional fuel and coolingGet out of my thoughts lol.
It’s kind of going to be the limit on pump gas, at least if it’s not e85. Going to be tough keeping the tune in check with a dcr of around 9.3.
Why? lol high compression? I tune these up to 16psi on pump gas.... a bit of water injection goes a long way as well. [but racecar] we have a pumpgas class that guys like to run down here.... you learn to get creativeGet out of my thoughts lol.
the car made 422hp to the tire with the smaller cam I had in it 2.5 years ago. Should be good for 600+ without breaking a sweat.Why? lol high compression? I tune these up to 16psi on pump gas.... a bit of water injection goes a long way as well. [but racecar] we have a pumpgas class that guys like to run down here.... you learn to get creative
honestly if the engine makes around 350 whp before the turbo then 8-10psi should net you north of 550Whp. Thats plenty for a streetcar
E85 seems to be the fuel of the gods.. lol We take stock e7 headed longblocks and cram all the boost into them for the 1/8th mile and guys running down in the low 6's rowing gears, they dont last long though.
